Found! Fuel lines
calinva
Shenandoah Valley
Ford Ranger XLT
Looking for both fuel lines that go from Fuel pump to the filter w/fittings 2011 Ranger XLT 4.0 extended cab or info on parts to make them.
calinva
Shenandoah Valley
Ford Ranger XLT
I'll check them out. Thanks
Uncle Gump
Boomers gotta Boom
TRS 25th Anniversary
14,070
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Ya know if you can't find complete lines... there is a few line repair options.
I bought a Dorman nylon fuel line repair kit a year or two ago. The tool makes short work of pushing fittings into new nylon line. They also sell about any connector you might need.
Looks like the price on the tool went up a good 25% since I bought mine.
calinva
Shenandoah Valley
Ford Ranger XLT
I've seen those and if I can't get the actual lines I'll have to go that route. Besides the tool do you know the line sizes ?
bergz0
9
nj
leveling kit
31x10.50x15
If an 01 is the same or close I have a parts truck I'd pull them from and sell them to you
lil_Blue_Ford
Cut & Weld
6,630
Butler, PA, USSA
5.0l
4”
I went a different route when I needed lines on my 00. While what Gump used works just fine, I wanted a little more versatility so I went to AN lines and fittings. Used -6 PTFE AN line and fittings. More expensive, but I can also use the same line and basic fittings for other stuff like transmission cooler lines and heater hose stuff and the like. I went that route because I planned on doing stuff like that and wanted one system to cover multiple needs. If you don’t plan to need that versatility, then what Gump suggested will work.
Some lines on Rangers are 5/16” and some are 3/8”. -6AN is 3/8” and is fine for use with all fuel lines, I was worried but the size difference at first over 5/16” but it’s proven a non-issue.
Uncle Gump
Boomers gotta Boom
14,070
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
The early Rangers had a mix of 3/8 and 5/16... the bigger size used for fuel return the smaller for the pressurized side.
I haven't had to fix the later model Rangers I've owned... so I can't say positively. It should be easy enough to put a caliper on the line and subtract for the I.D. to get the right size line.
The reason I just stayed nylon... it plain works... for a long time even in the rust belt.
franklin2
1,848
Virginia
In all cases I have run into, nylon tubing goes by OD.
bergz0
9
nj
leveling kit
31x10.50x15
Is 01 and 11 comparable?
bergz0
9
nj
leveling kit
31x10.50x15
Alright. I have an 01 I'm parting out if it interests you
RepairmanDan
7
Jackson MI.
255 x70 xR16
@bergz0 hey would you have the line from the fuel pump assembly to the vapor canister? I have an 09 Ranger 4x4 S.port
calinva
Shenandoah Valley
Ford Ranger XLT
Sorry for being late updating my thread but I fortunately found two brand new factory fuel lines and finally have my 2011Ranger back together and running as good as ever. Thanks to all that responded and I appreciate you all. Cal
TexasDuck66
July Truck of The Month
