2.3L ('83-'97) Fuel leak, 1989 base model
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
Marine GOOP will, but it's not even close to safe for use with gasoline. If you just wanted to put something over it AFTER a proper repair (welding) just to protect the patch, then goop would work. Shouldn't be necessary though.
BuckHilt
9
Winnsboro, SC
Stock
Stock
195-70R14
Old age and deception beats youth and enthusiasm every time.
It's fixed! Thanks for all the input.
The leak was at the front of the tank around the mount for the steel shield. I welded it and epoxied over the weld with an epoxy specifically for plastic gas tanks.
BuckHilt
9
Winnsboro, SC
Stock
Stock
195-70R14
Welded it and problem solved. (for about 8 months) Now it's leaking again!
Sherman shows a replacement tank, so I ordered thru CARiD. 1st one they sent was for an F-150 and was nowhere near close. Next one was listed for an 89 Ranger. It's steel and a different configuration than the stock tank - fuel pump/sender won't fit, filler is under the crossmember, etc.
scotts90ranger
4,366
Dayton Oregon
2.3 Turbo
'89 was first year of plastic tank I think... but holy cow... an F150 tank has to be a lot bigger, how do they screw that up?
BuckHilt
9
Winnsboro, SC
Stock
Stock
195-70R14
Aftermarket P/N is F14D on both. Sherman makes a metal tank for 1990 and up, but fit the '89 directly. Interesting fact is the 1990 has a different fuel pump spec than the 1989, but the '89 pump P/N says it also works in later models.
I'm trying to decide whether to try a kluge to make the '90 tank work in my truck or to weld the plastic tank again.
89Twincharge
182
Water weld is a good product for gas tanks... sticks when wet and I have personally used it on gas tanks and oil pans with great success but only as a bandaid... may want to junkyard dig to find what you need!
