nickname23
- Aug 6, 2024
- 54
- Texas
- Ford Ranger
- Engine Type
- 3.0 V6
- 2WD / 4WD
- 2WD
- My credo
- Did partial rebuild in the street 3 days, shop takes 3 days. Don't need a Shop
My ranger is giving me a hissy fit. He starts only once per day and I believe it's because gas floods the engine.
Had to replace the Pump and Lines w new filter and drained the tank because of water. Replaced Relay and rewired positive terminal. Replaced plugs because they were shot.
Don't think compression is an issue if I wait until morning it fires up and I can drive like a bat out of hell shifting through every gear and idling isn't an issue.
Thinking it's just still flooded so the new plugs are not going to do much until it dries, anyone else have an idea? It's definitely got fuel pressure once it fires like a good 2-3 inch spray off the test valve but once it's hot with the old plugs it won't stay running even if I bump start it with only clutch.
TPS is working, fuel regulator is with the pump assembly I've swapped the pump twice. Yes I ran HEET so I doubt it's water thinking it's pumping too much gas?
