Front wheel excluder seal
gw33gp
536
Costa Mesa, CA
4.0 SOHC
33"
I discovered my right front wheel bearing was going bad. Since I have 4WD, I had to replace the hub. I was surprised how straight forward and easy it was.
When I had the hub out, I noticed what looked like plastic that fit up against the outboard CV joint. It fits between the hub and outboard CV joint. I looked it up in my Ford Workshop Manual and it is call the front wheel excluder seal. I noticed it had some cracks in it but did not have one to replace it. I needed to get everything back together so I reassembled without replacing it. There was no leaks or any sign of failure.
So, what is the function of that excluder seal? Should I be concerned about the small cracks? The hub has its own seals, so it should not have anything to do with those bearing.
gw33gp
536
Costa Mesa, CA
4.0 SOHC
33"
It looks like I am not the only one that doesn't know much about this seal. I spoke with the dealership where I obtained the front hubs and found the latest part number for it. It is YL2Z-3K070-AA. They called it a dust seal and it is no longer available.
So, its function is pretty much what I suspected it to be. I have found NOS warehouses that have it but they indicate it does not fit my vehicle. Then I found an old post on TRS that started in 2008 regarding this dust seal and mentioned the last time the dealer installed one, it was the YL2Z-3K070-AA part number. So it appears that is the correct part.
Now, I am in the process of ordering it. I probably should order 2 but the left side one still looks good and they are not cheap.
