robotzombies
- Jun 2, 2015
- Reaction score
- 13
- Location
- Seattle, WA
- Make / Model
- Ford
- Engine Type
- 2.9 V6
- Engine Size
- 2.9
- Manual
- 2WD / 4WD
- 4WD
- Total Lift
- 3"
- Tire Size
- 33"
Hey everyone. I'm looking to do some wheel bearing and spindle replacement soon. In the past, I have had issues with wheel bearings not going onto the spindle very well. To the point where I have to give up and reuse old ones because the new ones just won't go on all the way. They fit into the rotor just fine, it's just the spindle/bearing combo that's the problem. Anyone have this issue, or am I just getting wrong part numbers?
The axle is a Dana 35 from a 1992 Ford Ranger. I'm using Spicer spindles (707166X) and Timken bearings (Set37). As far as I can tell, these are the correct part numbers for this axle, and the Timken Set37 should work for both inner and outer.
Any thoughts on making installation easier or alternative part numbers?
Edit: just looking at this page: https://www.therangerstation.com/tech_library/pdf_documents/Dana_Ford_35.pdf
Looks like the spindle is probably the correct spindle:
And it looks like the inner and outer should be the same bearings (items 55 and 57):
This is the 706110X page directly from Spicer that gives dimensions for the bearings: https://www.danaaftermarket.com/spicer-automotive/automotive-axle/bearings/part/wheel-bearing-assembly/706110X?cat1=LVB&cat2=LA&cat3=BRG&cp=0&catalog=PIMS_NA&partType=PART
Here is a catalog from Timken that seems to mirror the bearing dimensions, so Set37 from Timken looks to be the same as 706110X from Spicer:
Can't seem to find any spindle dimension information from Spicer, or any measurements from anyone else selling them, for that matter.
