- Aug 7, 2007
- 531
- Costa Mesa, CA
- Ford
- Engine Type
- 4.0 V6
- Engine Size
- 4.0 SOHC
- 2WD / 4WD
- 4WD
- Tire Size
- 33"
I could not find a section specifically for drive shafts and this looked to be as close as I could get.
One of my front drive shaft bolts for the end that connects to the differential got damaged, and with that little Torx drive it is difficult to torque to spec without the Torx bit slipping out. I contacted a Ford dealership and they want $13 apiece for them. I will pay that if I have to but would like to find some with a 12 point drive if they would work. There is not much room for a wrench on the exterior. The existing bolts do have a hex on the outside but the U strap does not leave enough room for a wrench.
I am pretty sure they are 8mm bolts but don't know what the length is. I will pull one out if I have to start doing a search.
Has anyone been able to find a substitute for this bolt? I am thinking a 12 point bolt head would be smaller with a flange like the rear drive shaft 12mm bolts, and would leave enough room to allow a socket to fit on it.
