alllw88
- Sep 27, 2007
- 0
- SF
- Ford
Hi all, I am going to replace the front rotors and pads on my 88 Bronco ll 4x4 ASAP. The left side rotor is too close to the minimum thickness limit, probably the right too, and the right rotor has a crack on the outer surface. (edge towards the hub)
I have never worked on these types of Ford brakes and have a few ???
First how do I remove the caliper pins...it looks to be the split shell type.
Do I need any special tools to get the rotors off since it has a lot of parts to remove there.
Also when I removed the right rear tire off to fix a fix I noticed that the axle had some play. I could pull it in-out about .100". I didn't measure this play but is there suppose to be any play?
Thanks for your help
Al
Al
