front axle
Blueranger99
lebanon, pa
4.0l v6, k&n box filter- this thing sucks... air
is it possible to change my open front dif to a limited slip dif? my truck has 3.73s in it.
Toms01PSD
37
Sanford, NC
7.3
How about a locker in the front? I believe you'd have to switch the open carrier for a limited slip carrier. If you just dropped the front axle you could pull the cover and install a lock-right locker in there.
dogboy
14
Enumclaw/ Carbonado, WA
'93
Yes, it is entirely possible to do, but as Tom said, you will have to swap the open diff carrier, for one for a limited slip carrier. Where as installing a locker (like a Lock-Right) will go right into the carrier that you have now.
I'm just backing what he said.
Blueranger99
lebanon, pa
is the lockright a selectable locker? im asking because i still will be driving it on the road in the snow. also how much does one cost?
crawlin91
60
Crawlorado
2.9, 4.0
wont matter if its selectable unless the 4x4 is engaged and the hubs are locked which I wouldnt recommend on pavement
Toms01PSD
37
Sanford, NC
7.3
Nope, it's not selectable. You won't "need" a selectable locker because 4x4 won't be engaged...
Blueranger99
lebanon, pa
but will it cause trouble turnin with it in 4x4 on pavement in wintery conditions. this is kinda the reason i would like to put a limited slip in it.
Toms01PSD
37
Sanford, NC
7.3
I can't honestly give you an answer to that question as we don't get ridiculous amounts of snow here in the winter. Most of us get bread and milk and camp out inside when it snows. I don't believe it would considering it's not fully locked all the time. It's an automatic locker so it unlocks when you take turns.
Blueranger99
lebanon, pa
why didnt yall just say that. sounds like a good product.
86ford
rocky river ohio
FORD
4.0, abused and misunderstood
People run lockers in live front axles all the time, d30s in any jeep after the mid 80s had a live front axle (possibly exceptions with newer jeeps). His vac. hubs are his biggest enemy.
86
86ford
rocky river ohio
FORD
Its something you could get use to. I ran my B2 with a spool in the rear last winter.
86
Hahnsb2
36
Battle Ground WA
Ford-Dodge
4.0-5.2 Turbo
IMO, a LS would be worse up front in the snow with a live axle since there is always resistance between the 2 wheels, even in 2wd. A locker unlocks very easily in 2wd so it should be no problem in snow when in 2wd, when in 4x4 just use "neutral" throttle when cornering and it will unlock.
Personally I think you're be better of locking the rear though..
Blueranger99
lebanon, pa
well since i have a ls in the rear, is there really any need to change anything? for wheeling am i better off with the stock diff. does the front do alot, or is the rear more important? it sounds like there will be problems on road in snow if i do anything with the front. i found in snow that if my rear tires are worn down i slide all over the place, but id i swapped the better tires from the front to the back i got much better traction. i would have thought that with the weight of the motor in the front, that better tires on the front would give me better traction. with the better tires on the back instead of the front i found that i could go through snow in 2wd better than 4wd with the better tires on the front.
my truck already wheels like a champ, i just wanted to see if i could make it wheel even better without makin it worse on the road in snow.
Beanmachine7000
5
Tennessee
Lock it up and both ends... That's what I'd do... A L/S is a locker wanna be... Although I have been surprised with my factory Trac-Loc, it is still no way near a locker...
Blueranger99
lebanon, pa
i have an issue of fourwheeler mag that has an article about lsd's and lockers, im gonna read it again. maybe i can come up with something. are lockright's real expensive?
