Free Truck ......
jon440x
Mazda
Ok a friend of a friend is going to give me a 97 ford ranger 2wd Auto with a 4 banger in it.
I havent seen the truck yet but i am told this guy is still driving it, but it has a trans problem.
I am told the trans problem is when it is shifting from 1st to second, he said it is almost like you need to let off the gas and then get back on it again for it to shift.
I think that this truck has a 4R44E trans in it, i might be wrong. :dntknw:
Is this a common problem ?
I am hopping it is something simple
Thanks Jon
racsan
4,420
central ohio
ford/escape
2.5 (4 Cylinder)
2.5/151 I-4
the grey-t escape
well the price is right, id swap in a manual. i dont know much about automatics. what few ive had i change fluid/filter every 30-50 thousand miles.
________
Lincoln (automobile) picture
rboyer
4.hoe
For the price you can't go wrong! Off the top of my head I can think of three junkyards local to me that give $500 if you drive your truck in. If a junkyard is willing to pay that much, then free sounds good to me.
pillen140
45
winston-salem, NC
are those vacuum operated? if so, could be a leak.... but i dont know if those are vacuum controled.
High Desert Ranger
High Desert, Calif
Nope it's all electronic.
Try a transfilter and fluid, and some TransX maybe the 75k Mileage stuff.
Sounds like a sticky solenoid.
pillen140
45
winston-salem, NC
oh, okay! thanks. thats what sucks with electric, you never know what the deal is.
MAKG
19
California central coast
That truck will certainly be worth the cost of a junkyard transmission.
mhughes165
9
302
id get junkyard 5spd parts to swap into it, the price is right and ull have a nice little truck for 250-300 a junkyard would charge ya for the 5spd stuff
rboyer
4.hoe
I don't know about you, but with the prices at the yards around here you can do the swap for 150-200 if you wait for the stuff to go on sale. Even if it costs 300 though, that's still a good price to pay if the end result is a 5spd ranger that's good on gas.
jon440x
Mazda
ok seen the truck this weekend .......... its a sweet little truck for free ....... needs paint and a windshield, exhaust and a few other odds and ends ...........
the truck has had a hard life but still very useable
it has 260000 km on it
the truck starts first flick, put it into drive and its like something is slipping ........ revs and revs but the truck barely moves, once it does this continues to happen till the truck warms up, then it is drivable with min slippage .........
My therory is ...... the fluid or filter has never been changed in the trans and the filter is blocked ......... or that is where i am going to start .........
I think it has a 4R44E trans ..........
I know that there is a Common Fix For 4R55E / 5R55E Transmissions With A Bad Separator Plate And Valve Body Gasket, when this is a problem how does the truck act ?
Is there any way for me to tell if the gasket is gone ?
Jon
Caps4x4
Puyallup, WA
2000 & 1989 & 1
2000 Ranger 3.0
3.0 and 2.9s
Call your local Ford fellow, and ask about any TSB's that might apply to the truck. I have a 4r44e in my 2000 3.0 and I'm looking into the separator plate update along with replacing the solenoids. My truck hangs in 1st before shifting to 2nd. And I get the O/D flashing when it tries to shift into 4th. A good way to test in the gasket it leaking, is to put the truck into 1st gear manually and bring the truck up to 20-25mph and maybe 4,000 rpms and then let go of the throttle. Do the rpms drop completely off to say.. 1,000Rpms? or Does it hold and the rpms come down with the speed. This is called manual 1st braking. If the rpms drop faster then the speed drops, you probably have the gasket problem... If it holds, then it may be something electrical in the tranny....
The 4r44e is a junk transmission, you really would be better off dumping a 5spd into her, but thats IMHO.
My 2 cents.
-Russ
jon440x
Mazda
Thanks for the insite i will do that as soon as i get the truck ..........
jon440x
Mazda
My 2 cents.
-Russ
Thanks for the reply but i dont think that this truck is sticking in gear, its more of a slip
jon440x
Mazda
Could this be a broken band
rickcdewitt
5
nor-cal
4-0 swap
hes not asking if it sticks hes telling you theres aproblem if theres no compression braking using that procedure.
