Frame reliability
Nick851
Vancouver
Hey im new here and was looking for some advice im going to look at a b4000 today model year 2000 and was wondering if there is anything i should be looking for specifically. The engine and transmission have 160'000k and body/frame have 285'000k should i be woried about rust
Colin
182
ON Canada
Mazda
Is rust an issue where you live?
Take it to a shop and get them to do a pre-purchase inspection?
pjtoledo
2,965
Toledo Ohio
Fords
3.0 2.3
if they use salt on the roads rust is a problem. check the frame, tap on it with a hammer to find soft spots.
get it sprayed with rust fluid.
91stranger
512
Whats round on the sides and hi in the middle-OHIO
Gets Mo Chicks
4.2 straight six powered by gremlins, goblins and mudbloods.
These are notorious for leaf spring hangers goin bad. The front leaf spring brackets are normally fine (also a weak spot for these frames as that's where mine broke on my 96) but the back brackets and hangers normally fail/rust apart. Also check issues with the motor swap since you never know if someone did a half ass job. Rust is ALWAYS an issue no matter where you live but it is worse up north. Do you know what engine it has? The 4.0's had timing chain issues... If it has a bed liner try to pull it up to see if the bed is rotted out. Other than basic fluid checks (check level, color and check for leaks) I learned you can tell a lot about a vehicle by looking underneath it. If something looks skeptical then just use that against the seller to lower the price. Haggle because no one ever lists their rock bottom price.
