Forged Internals?
bergilong
I've got a '94 ranger and I want to make it go a little faster. The first thing that comes to mind is to turbo it. Does my engine have forged internals so I can actually run some boost or do I have to get a different engine? Thanks for your time.
Sent from my ONE A2005 using Tapatalk
scotts90ranger
4,231
Dayton Oregon
2.3 Turbo
Everything but the pistons is capable of handling around 300hp, the pistons are good for a fair amount if you keep it from pinging but being 9:1 and cast most people say to limit it to 5psi max, and you'll probably want bigger injectors to get that far
bergilong
So if I put some forged pistons in it I should be able to make some good power? Thanks again.
cbr600rx7
North East USA
Ford and Ford
2.3, 360ci, 5.0
It's not exactly that easy. Putting normal ford turbo pistons into a ranger engine drops the compression a considerable amount down to around 8 to 1 from what I understand. Your better off just buying aftermarket forged pistons with around a 8.7-9.0 final CR ratio after taking your cylinder head and rods into consideration. Your other option is to just buy a turbo long block which is what most do.
scotts90ranger
4,231
Dayton Oregon
2.3 Turbo
Forged pistons of any sort are $$$, there's some circle track forged pistons out there for reasonable money but they apparently aren't recommended for forced induction
bergilong
If I were to put a turbo 2.3 in it, I'd just buy a turbo long block. I think I'm just gonna put a 5.0 in it.
vinsonp
belen nm
im looking to turbo my 1990 2.3l ranger and ive found a set of forged pistons i think might work --->https://www.summitracing.com/parts/uem-ic946-020/overview/make/ford , if i can get these to fit with the addition of brown top injectors, a ebay turbo kit and a few sensors i could boost it but im thinking i might need a turbo coupe ECU? if i cant get mine flashed? or remapped? or whatever but i am concerned about a transmission if i plan on running moderate boost im not sure what could swap in behind the 2.3 and keep me 4x4 while holding up to say 200-250hp
scotts90ranger
4,231
Dayton Oregon
2.3 Turbo
If manual the M5OD is very reasonable, mine is making some noise but I've only changed bearings and synchro's and the trans has well over 300k on the clock...
Kirby N.
March Truck of The Month
