Ford ranger cold start problem??
Chris Bowles
New member
when i start my ranger it cranks for like 5 seconds befor it starts and when it does start it like sputters then firers. but it doesnt do it really when its warmed up. like itll start right up when its warm. any one have an i dea of wehat it is. i was thinking maybe a new starter, or spark plugs and wires???? any input on this?
Rock Auto 5% Discount Code: 57CD9601BD5AB4 Expires: July 1, 2019
mattpresley
Active member
13
Mesa, AZ
FORD F-250
6.2
Solid Axle Swap 4x4
what do you mean by sputters and fires? what I start mine cold it shakes til it warms up but only sometimes
4byRANGER
New member
FORD
3.0 turbo
maybe your fuel filter needs to be changed?
Chris Bowles
New member
i recently changed the fuel filter. and by sputter and fire up i mean like ill turn the keyy and it takes a while then when it does start it starts but like is in low rpm and sputters a little bit then idles at normal rate and runs fine
Big Jim M
New member
26
Austin
Try turning the key to the run position for 5 or 10 seconds to get the fuel pump to build up pressure before starting the engine. It is common for older vehicles to lose fuel pressure overnight. The fuel leaks backward into the fuel tank after a few hours.
Big JIm
Anger Ranger
New member
I had a problem like that with the Ignition coils once I had a VW. When it rained, the car hesitated, and smelled like gas. Check engine lights, rough idling and low rpms. Everything was like that until.......it warmed up.......I tried many things but then I thought they were the ignition coils because in other forums people had the same exact problems. You might get a new ignition coil or the "epoxy" solution, or warm up your truck earlier when it had rained overnight.
In other words, moist gets inside the coils and cause a misfire and then a "check engine light". When your car warms up, the heat evaporated the moist trapped inside.
For reference google this: "epoxy solution ignition coils jetta", you will be surprised that a lot of people had this problem.
Hope it helped you a bit.
swascott1981
New member
Yea I have the same problem I'll turn it over it sputters real bad then I'll cut it off and crank it again and its fine anyone know y it does that
UrbanRedneckKid
Active member
16
Cass Co, Missouri
Hook a scan tool up to it, see what the CTS (coolant temp sensor) reads.
Start there.
