Ford Ranger AMP bypass 1993
LostTraction
Okay so i've gone around to various shops looking for the bypass cable for the amp in my truck. 1993 Ford Ranger. Every shop has told me the truck doesn't have an amp but there is one behind the passenger side front kick panel. All the aftermarket connectors I have currently found have the wrong connections. I've tried to use parts from the same year explorer with no luck. The aftermarket plus has one side as an 8 pin across and the other connection is a 6 pin on top and 2 on the bottom which that connector fits in on one side but the 8 pin across isn't even close. Has anyone else ever dealt with an amp bypass that didn't have to rewire the whole thing?
SenorNoob
543
Middle Tennessee
1.5" Front + 4" Rear
245-70-R16
Well, for one, Howdy and welcome to TRS.
Second: Pictures of your parts? I can't really visualize it.
Earl43P
38
Farmington, Pa
Ford F250 4WD
1993 Ford Ranger Stereo Wiring
Constant 12V+ Green/Yellow
Switched 12V+ Yellow/Black
Ground Chassis
Illumination Blue/Red
Dimmer n/a
Antenna Trigger n/a
Antenna Right Front
Front Speakers 6 1/2" Doors
Left Front (+) Orange/Green
Left Front (-) Black/White
Right Front (+) White/Green
Right Front (-) Black/White
Rear Speakers 5" x 7" Rear Corners
Left Rear (+) Pink/Green
Left Rear (-) Pink/Blue
Right Rear (+) Pink/Blue
Right Rear (-) Green/Orange
This info is from the12volt.com.
1993 did offer a 4 channel amplifier, located exactly where yours is.
I'll take some photos from the 1993 Schematics book tonight for you.
Send me a Private Message with your e-mail address and I will send you those schematics.
Welcome to The Ranger Station.
AllanD
134
East-Central Pennsylvania
1987... sorta
'93 4.0
Somewhere around here I have a purpose made amp bypass cable that I'm not using and am unlikely to ever use.
Let me look around my cluttered garage and see if I can find it...
Woogie
15
Boise, ID
Mazda
2.3
Metra sells a bypass kit with all the connectors and wiring you need. It's on Amazon for about $16. Search for Metra 70-5605.
