Ford Granada rims
mc_muench
"Miller"waukee
I found some 14" cragers on CL and had a question, the ad says they're from a 1977 Ford Granada and 5 x 110mm? and I know that ranger rims are 5 x 114mm so I checked the tire fitment guide in the tech and it says they should fit, so maybe they guy selling just wrote it wrong, but there's an * after it but no add on, so my question is will they fit without any major mods?
ad
http://milwaukee.craigslist.org/for/1703295685.html
Robert_1967
13
White Pine, TN
302/2.9
best thing to do, is take a measuring tape with you and measure the bolt holes as it says to do in the tech section, or take one(rim) and try it on your truck.
Robert
Sasquatch_Ryda
Forum Staff - Retired
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
Same thing that I have on my 72 mustang.
They are 5 on 4.5 which is the same as the ranger
HareRazor
Montezuma
It should bolt up. I believe the center hole on the Granada wheels will be bigger than a 2wd ranger though.
press 1 for english
8
Arcadia, Fl
2.3
Those are oblong bolt holes on the wheels that require a unilug type nut. They rarely ride real good.
Stay away from these.
superds
80
ND
Ford Bronco II
2" body. 1.5" coil spring spacers/rear block
Does that require somthing like these:
or these:
Robert_1967
13
White Pine, TN
302/2.9
if the rims take those type of lugs, dont buy them, the center hole has to be right so the wheel won't wobble, I had a set of old slot mags once on a car that had the long holes and took those type of lugs and washers, rode like really bad, I could never get the wheel centered on the hub to not wobble
Robert
mc_muench
"Miller"waukee
all righty then, i think i pass on em if there is that big of a chance for badness
