For those that have swapped in 70s F150 coil buckets...
farmer
54
Rochester, NH
Mix of 78-96
Ford donors
357w
Solid Axle Swap 4x4
13ish
39.5x15.5
...how did you make the bucket sit flat on the drivers side with the power steering box bump? I'm about to start on this and any tips from personal experience would be great.
Btw my Dana 44 is narrowed so I don't want to make the buckets hang out a lot on each side.
Rock Auto 5% Discount Code: BD8D9A3814E19D Expires July 5th, 2022
Hagan
08/2013 OTOTM Winner
11
Salem, OR
2.3
I figured out where the bucket needed to go. I cut it to fit over the bump and welded a new piece in. Sorry thr photo is kind ofm blurry.
farmer
54
Rochester, NH
Mix of 78-96
Ford donors
357w
Solid Axle Swap 4x4
13ish
39.5x15.5
Thanks for the pic!
Did you add any more bolts/bracing to the bucket or just use 2 bolts? Either hole line up with an existing hole in the frame?
Hagan
11
Salem, OR
2.3
I welded a plate on the bottom and have 2 bolts on the bottom and 2 bolts on the top.
I believe I had to drill 4 holes on each side but I can't remember for sure.
armyhooker
Ballistic fabrication has some adjustable buckets. I used them on mine and they work greay
