- Aug 7, 2007
- 18
- Opelousas La.
- Ranger
I picked up 4 302's yesterday, one was a mexican block, one was a D8VE-6015-A3A casting, which turned out to be a clone of the Mex block after I dis-assembled it. The only difference between the two is the absence of the two bolt bosses on the front of the block that help to I'd a Mex block. I weighed both, the Mex block was 136 lbs, the D8VE was 135 lbs, but it's also a 60 overbore vs the Mex's std bores. Of the other 2 blocks, one is a C8OE casting, the other I suspect is an early 80's block as it's got an aluminum 2 bbl intake. When I get the C8 block torn down, I'm going to weigh it and see how it compares to the Mex/D8VE blocks. Both blocks will go up for sale as soon as I can get em both mag'd. Although the D8VE block is 60 over, the walls are thick enough to go another 20, and make a 356 inch stroker with a 3.4 crank.
