Gacknar
- Aug 6, 2007
- 0
- Age
- 47
- Douglasville, Ga
- Ford
- Engine Size
- 2.9L
1989 Ranger STX High-rider, regular cab 4x4 with 6" lift.
I have recently completed a FM146 to M5OD swap, but have encountered a problem with the shift boot and boot bezel.
I cut the carpet and moved the bezel forward (+/-) 3" to match the M5OD's shifter, and I was able to cut the carpet in a way that I could cover the gap left from moving the bezel forward.
The problem is I have a manual T-Case, and the lever hits the bezel when trying to shift past 4-Hi. Not to mention the boot in no way fits with the bezel so far forward.
I have gone to every online dealer I know of, and all of my local Junk-Yards. None of them have a manual T-Case M5OD combo RBV or its associated shift boot/bezel.
So my questions are.
1. Where there M5OD/Manual T-case combos from the factory?
2. If so, where can I buy the shift boot and bezel.
3. Are there other options?
The M5OD swap seems fairly common, so someone has had to solve this problem, but the only threads I found on it were these.
http://www.therangerstation.com/forums/showthread.php?t=48953&highlight=SHIFT+BOOT
http://www.therangerstation.com/forums/showthread.php?t=125381&highlight=SHIFT+BOOT
And no one answered the problem.
