- Jan 16, 2020
- 50
- Ohio
- BII, Rangers
- 2WD / 4WD
- 4WD
Greetings. I'm cleaning up the 5spd swap on my '86 BII. Truck was originally an auto w/the floor mounted transfer case shifter. The previous owner swapped in a FM145 5spd. I'm assuming it was out of a ranger because the front drive shaft is old and crusty and the rear is brand new. Dude bragged about that. So I'm assuming it's now running whatever transfer case is normally behind a FM145 (I'm still learning) and he got a new rear shaft since one from a Ranger won't work. I got my hands on an original floor boot and whatnot so I yanked the old mess off to discover my 4x4 shifter is all hacked and floppy. Can someone show me the difference between the brackets and linkage assembly between a auto and manual trans with the floor 4x4 shifter? Or has a good side picture of it bolted to a FM145? I'd go back to where I got the shifter boot but that junkyard is 500 miles away. Also I'd love to get the clutch interlock functioning but that's another adventure.
Here is what I'm dealing with.
Thanks.
Thanks.
