flex plate keeps breaking
spanky50
Law Enforcement
6
muncie,in
ford ranger XLT
4" rough country
32" cooper STT
hi guys, I'm having a problems with my flex plate breaking? 97 4.0 4x4 ranger auto
franklin2
1,974
Virginia
How many times has it broken?
RobbieD
2.9l Mafia
4,303
Georgia
On one of my trucks I went through 3 broken flex plates before giving up and converting it to manual. 1990 2.9 / A4LD.
All of my plates cracked at the center, around the crank bolts. The only thing that made sense to me, was that one of the two, probably the transmission, was machined out of spec which either made the center-to-center (of the shafts) not align correctly, or that the parallelism was off between the two.
lil_Blue_Ford
Cut & Weld
TRS 25th Anniversary
7,670
Butler, PA, USSA
5.0l
4”
Where is it breaking? Is there evidence that the starter is causing a problem?
spanky50
Law Enforcement
6
muncie,in
ford ranger XLT
4" rough country
32" cooper STT
around the crank. this one broke in 2 days. this is number 2. i put new motor and trans in 2 years ago. 10,000 miles
franklin2
1,974
Virginia
Do you suppose the dowel pins fell out that are pressed into the engine? Or possibly the engine was rebuilt and the dowel pins were removed and they forgot to put them back in place? The bolts do not align the engine and trans, the dowel pins do that.
2011Supercab
651
Washington
Toyota Tacoma
That's exactly what I was thinking, both dowel pins are missing.
901wd#2
125
Vermont
Ford ranger
Bad thrust bearings and crank walk?
bobbywalter
TRS Technical Staff
Ugly Truck of Month
6,048
woodhaven mi
FORD mostly
BIGGER
sawzall?
you have to replace the spacer every time you take it apart....well...if its been on there long enough to murder a transmission
bobbywalter
TRS Technical Staff
Ugly Truck of Month
6,048
woodhaven mi
FORD mostly
BIGGER
sawzall?
its made out of powdered metal....and there is the later 97 plus flexplate that is thicker....its the one that dont have the 3 weld spots. and the newer tq converters have longer snouts....
when i do a a4ld 5r55 or whatever....those are part of the deal.
bobbywalter
TRS Technical Staff
Ugly Truck of Month
6,048
woodhaven mi
FORD mostly
BIGGER
sawzall?
that is the upgraded unit that is not powdered metal.
97.....you probably need the 8 hole...
Rick W
October Truck of The Month
25th Anniversary Merch
TRS-3 Ford Ranger Sponsors
