Fixing cracked dash pad with fiberglass, 86 ranger
Dlillie87
7
Florida
Ford/Ranger
Just wanted to share my progress on this project so far. Like a lot from this era, my dash pad was dry rotted and cracking Everytime it was touched. I looked into the aftermarket plastic replicas, but the reviews werent good. Figured I'd give this a shot and it's going great! I'm covering my vent holes because I've gutted the entire HVAC system. This is also my first time doing any glass work.
67028
67029
67030
This is what I started with, not in horrible shape, but would have just kept getting worse. The first thing I did was took a box cutter and opened the cracks up so that I could get Bondo down into them pretty good, then sanded everything smooth
67031
67032
Cleaned everything with denatured alcohol real well, I don't think acetone would be good for this. I also used epoxy resin, not the poly stuff typically used with fiberglass. The glass work I've been doing in stages with small pieces to get around all the curves. This same thing can be done and keep the original vent holes as long as you're careful not get too much resin where they sit into the dash
67039
67040
67041
67042
I have made more progress than this, but don't have more pictures at the moment. But I only have a little more glass to add the the vent holes to get them close to flush, then Ill sand everything, Bondo everything to fill any small holes, sand again, and paint back the original color. All in all this might cost me $100. I'll post more pictures Monday 🤙
RobbieD
2.9l Mafia
3,314
Georgia
Thanks for sharing this, and I'm interested in how it turns out. Good on you, for taking a shot at fixing one of these old dashes.
Junk Collector
4,704
Rapid City SD
Nice. Also curious to see the finished product! Most of the interior resto shops will put vinyl over them. Looks good but not quite OEM.
franklin2
1,712
Virginia
Bronco II
Here's a good video on the subject.
Dlillie87
7
Florida
Ford/Ranger
Good video. I was hesitant to use Bondo by itself since it has a tendency to crack, especially when it's applied thick. But I basically did what he did before the glass work. I like having the comfort of knowing my dash won't crack anymore, and I don't have to baby it
Dlillie87
7
Florida
Ford/Ranger
Progress pictures. Got the vent holes filled in. Should just need a good sanding, a little Bondo to smooth it out, and paint. All in all I'm really happy with how it's turning out.
67159
67160
dvdswan
2,899
Seattle, WA
Ranger XLT 2WD
Very cool.
Although its obviously for a boat engine, one might get roasted for posting images with a Honda in it. :unsure:
Dlillie87
7
Florida
Ford/Ranger
Primer coat. Turned out pretty good I think. Itll be the original blue when done
67234
67235
67236
RobbieD
2.9l Mafia
3,314
Georgia
That is looking good. I'm looking forward to seeing it installed back into the truck.
Dlillie87
7
Florida
Ford/Ranger
It will be a while before it gets put back in. I'm pulling the body off frame and going over everything.
67248
Kirby N.
March Truck of The Month
