- Feb 22, 2024
- 19
- Jonesboro, Georgia
- Ranger XLT
- Engine Type
- 3.0 V6
- 2WD / 4WD
- 2WD
- My credo
- Any sufficiently advanced technology is indistinguishable from magic. -Arthur C. Clarke
My Ranger's passenger brake adjuster assembly had come apart and damaged the drum. I have replaced the rear brakes following the example of the intact drivers' brake assembly. It looks correct on both sides with the adjusters on the correct side. My problem is that when I adjusted the shoes to allow the drum to be fitted onto the assembly and test drove afterwards, the brakes are giving off a burning smell after an 8 mile drive. I checked the brakes with a non contact thermometer and the passenger drum was 202 degrees and the drivers 100 degrees. Is this normal and are the brakes supposed to smell so when first installed? I replaced the 10 inch drums, shoes, the shoe hardware and the adjuster components. When I would apply the brakes in a long slowdown, they would begin to shudder slightly. I found and read this thread: https://www.therangerstation.com/forums/index.php?threads/drivers-side-drum-getting-hot-after-brake-job.208999/#post-2035525
but it doesn't help much. Any help from an experienced person would be appreciated.
