First roadtrip, What do I need to do to the ranger.
HeadlandRam
Headland Al
2.3
As the title says, I am going on my first trip, it is gonna be around 800-1,00 miles round trip and I honestly don't know what I need to get done to make sure my truck can handle the long trip. I believe it is already reliable enough as is but I wanna be 100% sure,
I have done a tune up about a year ago, I have cleaned the air filter and just changed the oil 2 days ago. My tires are good and my brakes are good, I replaced the pads about a month ago. and as far as I know everything is Status 7
The only small issues right now is the occasional code for my Cam Position sensor, My stumbling when my a/c is on ( I already put stop leak in it and more freon and still have the issue, I know I also need to get some bigger gauge wiring for my big 3 upgrade) and a pull to the right but I have some Eccentric bushings for my radius arms I need to put on.
So What do I need to do to get ready for this long drive and y'all have any other helpful tips and tricks?
Bennybooster
EMT / Paramedic
37
Medford, Oregon.
You can only prepare so much, and usually what breaks is something you don't even think of. I would just go and see what happens
509lifted
Firefighter
10
chelan washington
2.8l, 4.0 v6
elk hunting every year and i drive about 1000 miles round trip plus driving around while there and i have an 84 b2 with a crappy motor i do nothing but change to studs for the snow and nothing happens i know that wont happen everytime i go but so far nothing has happened and u have a newer truck so u should be fine just dont worry go and have fun if something breaks fix it while on the road
Lucifer sam
13
1997
Check all fluids (including diff) bring some oil and anti freeze just in case, i would probably bring some tools.
I just went on a 700 mile trip and had my tires balanced before hand, the guy said they were pretty far out of wack. I couldnt believe the difference.
$20 well spent
det107
23
Vails Gate, NY
The only small issue right now is the occasional code for my Cam Position sensor
If I were you, I'd replace the Cam Position Synchronizer assembly-
doorgunner
Lab Rat for V.A. hospital
MTOTM Winner
2009 Truck of The Year
516
New Orleans (8' below sea level & sinking)
350+1
N/A
3/4
23570R15
JESUS Loves Ya!
a 12v mini air compressor & a tire plug/repair kit.......................and be sure you have a working jack/lug wrench.............just in case................AND a camera--you see weird stuff on a trip....;missingteeth;
alexpmcmurphy
chicago
the best thing you can do to prepare for a road trip is pack your tools where they are the easy to get to
robertc1024
133
San Marcos, TX
nada
2.9
Make sure your spare has air in it.
killj0y
11
Edinburg, TX
2.3l 4 Banger
Fix it till its broke!
You could change out your fuel filter of it's never been done, mine left me sorta stranded in the middle of no where on a road trip because that. Had to "blow it out" to go a while to get to the nearest town with a parts store, it took a bit, to many blink and you'll misses it Towns.
Clean your maf gently, and your icv.
Check the pcv, and take enough fluids, make sure you have a jack and jumper cables.
Keep a gallon of drinking water, you never know.
A good light for night repairs, maybe crappy set of Jeans and t for said repairs.
Make sure your Insurance and registration I'd up to date.
Plus everything these other guys have mentioned. :thumbup:
killj0y
11
Edinburg, TX
2.3l 4 Banger
And avoid offroading till you get to your destination, to many things break offroad lol.
LearjetMinako
12
Moore, OK
2.3L 140ci
Sounds like you did everything you need to. I've taken my Ranger from OKC, OK to Central Square, NY and back for a vacation. Ranger made it just fine. Thou under powered for the hilly terrian, just had to downshift to 4th before I went below 60mph. If I hit 55mph in 4th, drop to 3rd to keep speed while climbing.
