Finally have to pull the trans.
fastpakr
2,832
Roanoke, VA
I really don't think it's a concern either way. To date, I've never heard a story of any damage caused by one separating. And those that have removed theirs don't notice significant vibration...
9723
64
XLT
2.3
Yesterday, I started to put the exhaust back and discovered I'd forgotten to install the exhaust hanger that goes on the rear transmission mount. That took a little time. I also put in the shifter plate and shifter. The O2 sensors are in but I didn't connect the upstream sensor. With my new extension, I want to take my time zip tying the extra length of wire... somewhere. Bolt the fan shroud, put the starter in and fire it up, before taking it off the blocks so if I need to tighten it......the exhaust.
fastpakr
2,832
Roanoke, VA
It's coming together quickly. Great job on the repair work!
RobbieD
2.9l Mafia
3,449
Georgia
Good job. It has been a hard-fought battle, but you're about there.
9723
64
XLT
2.3
...on the battery charger.
9723
64
XLT
2.3
One lever of confidence comes from:
Every single bolt, nut or fastener I take off goes into a labeled ziplock bag and into a tub. At least that way I know I haven't missed anything. Haha, I learned that the hard way.
64
XLT
2.3
It started easily, sounded like the exhsust is tight and went in first gear easily. It's never done that. 20 years ago when I bought it, 1st gear was touchy to get, even at a dead stop....it never got worse so I was careful with it....sure went into 1st much better now.
... gonna check the gear oil in the diff before I take it off the blocks. I've got R-Purple gear oil on-hand.
RobbieD
2.9l Mafia
3,449
Georgia
Great! Hope to hear soon that you have had a good test drive.
9723
64
XLT
2.3
Yes last evening, I pulled it out, washed it and drove it to the convenience store for a pint of ice cream. The trip is only 6 miles, but includes 4 miles of interstate at 60-65 mph.
Doesn't look 24 years old, does it?
It works better then the entire 20 years I've had it. I'd always thought the syncros between 1-2-3 were worn out, but no. They work fine. It was the the slave/throwout that wasn't fully actuating.....the whole time. It's surprising it worked for 20 years, but I was always very careful with it, either matching the clutch/engine rpms or waiting till a full stop to put it in 1st.
I want to thank everyone that helped with advice, experience and encouragement. It made a big difference.
Thanks!
I have one other very different issue I've started a thread on here:
