Fiberglass bedsides
Jebadoo
Central PA
Mazda B3000 2wd
2" maybe?
245/60/14 Rear, 205/70/14 Front
4 Rangers so far. I work IT and enjoy the torture.
I understand that on the front you basically need everything ranger specific to convert to a ranger front end (header panel, headlights, fenders, etc)
But on the bed, I'd like to convert to a ranger fiberglass bedsides because mine is rotten rusted in spots, but not the "tub" itself.
I don't want to swap entire beds because I have a long bed b3000 and the 7ft seem to be hard to find.
Would I be able to just use the fiberglass bedsides with ranger tails, or will I need to change more (ie tailgate, bed tub itself)?
Curious Hound
Formerly EricBphoto
TRS 25th Anniversary
18,692
Wellford, SC
6"
I think the tub is different because the normal sides are not removable.
Colin
192
ON Canada
Mazda
You'll have drill out all the spot welds to remove the bed sides. But if they make 7ft fibreglass bed sides they will work.
Jebadoo
Central PA
Mazda B3000 2wd
2" maybe?
And I just need to switch to Ranger tail lights right? It's been a while since I owned one of these things and I forgot if the bedside determined the tail light or the "tub"
Curious Hound
Formerly EricBphoto
18,692
Wellford, SC
6"
I didn’t notice the 7ft detail. The flareside beds are short - 6ft. So, there’s no way that they’ll work on a 7ft bed tub.
Colin
192
ON Canada
Mazda
Yes but the mazdas are 3 bulb and the rangers 01? and up are 2 bulb, so you need to do some wiring.
But as Eric mentioned, are you doing aftermarket bed sides, or trying to use step side ones?
Jebadoo
Central PA
Mazda B3000 2wd
2" maybe?
Aftermarket prerunner style.
I should be able to find the older ranger tails fairly easily so I can use 3 bulb still
Colin
192
ON Canada
Mazda
Yeah they're cheap on rockauto
Rick W
October Truck of The Month
25th Anniversary Merch
