ericbphoto
Overlander in development
- Feb 7, 2016
- 16,530
- Age
- 59
- Wellford, SC
- Ford Ranger
- Engine Type
- 3.0 V6
- Engine Size
- 3.0L
- 2WD / 4WD
- 4WD
- Total Lift
- 6"
- Tire Size
- 35"
- My credo
Meanwhile, somewhere in China...My wife wanted me to plant a rose the other day, so I started digging where I was told to with the spade. Hit steel. Weird like 45* angle iron parallel with the surface but very attached. So I worked to one end of it and found where it quit. Went the other way and after about a foot found the end there. One web was broken and it went straight down. Look around for clues as to what the heck this could be and note we are coming straight off the corner of our well. If it isn't the leg to a windmill it is probably some sort of a stake to tie down a windmill.
Great.
So I ease into removing this with the handyman jack. Did not work and I got it stuck in the ground too. Making great progress now...
So I start thinking about how to pull the jack out of the ground, the only tractor I have with 3pt at the moment is the WD with a heavy solid steel toolbar ripper thing. Kinda light in the front but it should at least get the jack out. It didn't flinch.
Ok we got it here, lets tie onto whatever this is and give it a tug too. Picked the front of the tractor up and there was a pop and that was the end of that.
So we scooted the rose a little over to the side...
