Terry
- Sep 5, 2008
- 19
- Gardnerville, Nevada
- Ford Ranger
- Engine Size
- 2.9
I have an 1987 ranger that I pretty much built. It has dual tanks. It started running like it was loaded up or starving for fuel. I checked the codes and got a 95. I cleaned up the grounds like has been suggested. I also tested the fuel pressure. It is running on the low side 29 psi. I changed the regulator and the filter. It did not improve. I disconnected the vacuum line from the pressure regulator and tested it again. I got 36 psi that time. I think unregulated it should be over 78 psi? I tested it on both tanks and got the same results. I have a new high pressure pump in the box that have not been put in??
