Extended cab on standard cab longbed frame?
Vanner1993
New Jersey
460, 351M
I have an 86 standard cab longbed, I was wondering if an extended cab along with the extended cab bed would line up on my frame. I know the extended cabs have a shorter bed on first gens. Possible? I'm thinking about it if it works.
dangerranger83
5.0 HO under the hood!!!
54
Lafayette, IN
5.0 HO carbed with an np435 and np208
Awhile back I was told it will work but you will have to move the rear cab mounts and you will have to use the shorter bed. The extra cab space took away from the bed.
gribly
28
Maine
Honda
K20A3
I think you have to shorten the regular bed by a couple inches or shorten the longbed by a foot and then some. The cab will fit, hell - we have a member with a regular cab on an explorer frame.
Vanner1993
New Jersey
460, 351M
Ok, yeah i plan on taking the extended cab and the bed because it took away from the long bed. i parked next to one and they are the same length. OK, I'm gonna go inquire about saving it.
kunar
131
Toledo, Ohio
5.8l
No, they aren't the same length. Extended cab rangers (which all had 6' beds) are longer than reg cab long bed rangers. I think there was about a foot difference in wheelbase. With that said, an extended cab truck with a 5' bed would probably look pretty good IMO
superds
80
ND
Ford Bronco II
2" body. 1.5" coil spring spacers/rear block
Along with what Kunar was talking about, here are the approximate wheelbases of Rangers:
Reg Cab Short Box: 108"
Reg Cab Long Box: 114"
Supercab Short Box: 125"
88ranger89camaro
Firefighter
Squaw Valley, CA
2.3
i wish there was a extended cab, long bed ranger
Sunk
125
Everett, WA
3.5 Eco
You can do this with a 98+ truck, the frame rails are two pieces riveted together at the front leaf mount.
Sounds like a cool swap.
88ranger89camaro
Firefighter
Squaw Valley, CA
2.3
i would build one if i had the time and $$$$$, would also like to do the cummins 4BT swap with a good drivetrain to back it up ...... i seen on you tube a chevy 3500 with a cummins and a 13 speed eaton and some with 10 speeds, imagine that in a danger ranger with a 8.8 rear end :icon_hornsup:
simonsays
October 2010 OTOTM Winner
9
Carpinteria
I kinda have one, I've got fiberglass long-bedsides on my extracab ranger, but it doesn't exactly have a useable bed.
sent by another dumbass using Tapatalk.
