Explorer EFI into a first gen
Junk Collector
Truck of Month
5,785
Rapid City SD
There is a nice one listed here for $500...
'85 was the first year for the big inlet in the fuel tank so I am only limited by my fuel gauge for what will work there. I would need a new feed line and I would have to add a return no matter what I do.
500 bucks is way too much for Pro-jection IMO, I know a bunch of guys that ran it back in the day and it was always a hot mess on modified engines. It got removed from a lot of trucks because it was hard to tune/nobody knew how. Stock engines or close though - totally fine - I may actually know someone who has the whole setup and would probably part with it. I'll ask him just cuz I'm curious.
86-88 sending unit will work perfect for EFI w/ return. Bend up some brake line, add ends & you're good to go.
Wallows in rivers
21,555
SW Iowa
Looking into it more I don't know if it would be a huge improvement over a carb. Rather than jets/rods I would have to play with screws to adjust for elevation, I am not sure it is really worth the hassle.
Otherwise I really have no complaints with what I have.
If I just stayed around home for the right price it would be a fun period correct accessory.
Junk Collector
Truck of Month
5,785
Rapid City SD
Hmm, that is a bummer.
My buddy used Affordable Fuel Injection on the 304 in his Jeep. No engine mods and he is pretty happy with it, seems like a high quality setup and it's just over a grand with a distributor included. It's basically OBD-1 TBI though and their little computer module runs whatever code GM was using back in the early 90's. I guess I would be tempted to use a gen 2 Sniper setup on a modified engine but again for a stock one it should work well.
Wallows in rivers
21,555
SW Iowa
They have the PROM chip programmed to match the engine.
And they need a special air cleaner because the top of the throttle body projects into the air cleaner so high.
Been down that rabbit hole too...
Not really much cheaper than a Sniper either.
bobbywalter
TRS Technical Staff
Ugly Truck of Month
TRS 25th Anniversary
6,124
woodhaven mi
FORD mostly
BIGGER
sawzall?
So my first question is, why go that route instead of a FiTech/Sniper/Affordable EFI/etc? Just seems like a lot more fiddling is required to use stock parts which equals more time.
If you can round up a Mustang or Crown Vic/Grand Marquis upper & lower intake, you can put the throttle body on either side. The upper intake can be flipped either way. I've got mine on the driver's side and am really happy with where everything landed.
i do that with explorer intakes too. of course the lightening is already like that.
bobbywalter
TRS Technical Staff
Ugly Truck of Month
6,124
woodhaven mi
FORD mostly
BIGGER
sawzall?
JoshT
3,299
Macon/Fort Valley, GA
Missed that and it's not a bad idea either. Biggest reason to keep it flipped to the right is to use with the Explorer stuff. The EGR elbow, throttle body, bracketry, and intake tube along with the assiciated Explorer harness that is laid out of it. If you aren't using that stuff, might as well put those things where they are most convenient, and seeing as this is a first gen ranger with the battery on the right, that would be with them to the left.
Since you are already running the carburetor, the easiest option would really be a TB EFI system like the Holley sniper or the Killshot that Bobby posted. I've used Sniper and it works. Never used Killshot, but I assume that Bobby has if he's recommending it.
If you want to do the work for multiport, I still think that one of the aftermarket systems would be your best move. Most of them can be set up using standard off the shelf sensors as long as you input the sensor data properly. Run the explorer intake, a second hand Mustang throttle body, get the few sensors you need and wire it up.
If you really want to stick with a stock EFI system, and I understand the draw, I really think I'd be looking into the older Fox Mustang stuff that uses the A9L ECU. That conversion was so popular for EFI swaps and MAF conversions on 302s that the information and components will probably be available for a long time to come. You can probably buy every piece you'd need brand new, the wiring harness included. If you buy all new, you'll be spending about as much as one of the aftermarket kits.
bobbywalter
TRS Technical Staff
Ugly Truck of Month
6,124
woodhaven mi
FORD mostly
BIGGER
sawzall?
for the multi port LS engine in the thing that identifies as a ranger Z car......i was going to use the aces but was unable to get a unit when i needed it .... when it was in development, it was on a project i was working with and i liked the fact it was running stereo widebands over the holley single wideband with the terminator x.
that engine had a radical cam and heads with a high dollar intake and 300 shot, so i really could not tell if it was more efficient.
it lasted about 14 months and that car has a dominator system now. never found out what the issue was, i know they sent it in.
the tbi units so far are decent. i worked with the fi tech stuff and its essentially that.
i would buy two.
right now i want to buy a spare holley ecm so i have one, but the aces setup i have a deal for is actually a little bit cheaper.
sigh. that is just a kick in the berries.
if we go to a hemi....i will for sure be running the aces. if we decide to use the windsor i might run the tbi aces.... a 150 coyote....probably the terminator.
in your case Justin.
i would consider the lower power tbi setup they have.
but i probably have all the shit you need to run eec5. and 180 the intake like shran with no egr elbow and the tb on a spacer and a snorkel up the a pillar.
Wallows in rivers
21,555
SW Iowa
I had seen Aces on FB, I have never heard of them before. On the ad they bombarded me with on FB 6mo that I haven't been able to find since asked not to see it anymore someone asks if it will work with Duraspark and they just said no. I don't know why or if it was the whole kit that already had the ignition system with it or what. There wasn't much out about them then, I see they have put out a bunch of videos since.
I will have to check into Aces some more since they get the Bobby seal of approval.
I watched a video last night and they flat out say what injectors, O2 sensors and TPS you can order from a parts store which was really nice.
I am not like totally married to Duraspark but having to add the ignition takes it back up to the price of a Sniper. And if I am going to change ignition I would be cross shopping with MSD or something more mainstream. But if I could I would be fine doing that later...
My build theory of the truck, trying to keep it look like it came how it is really complicates multiport...
bobbywalter
TRS Technical Staff
Ugly Truck of Month
6,124
woodhaven mi
FORD mostly
BIGGER
sawzall?
they dont have my seal of approval.
just like the fi tech or the holley....i would buy two...or at least on long trips keep your carb fresh and clean in a pelican box with your spare pistol.
the suck of aftermarket efi no matter what it is...cant just walk into a parts store or junkyard for a ecm.
same thing with my captain cavepig diesel. i have spare shit for that too.
i am willing to risk them as a try if the situation presents itself. i am trapped becasue i have to rewire the 350 that thinks it is a ranger if i save 50 bux by purchasing the aces instead of a spare terminator ecm.
we will be driving the Z long distances eventually so most likely i will be buying a spare terminator.
Wallows in rivers
21,555
SW Iowa
Watching youtube last night and my kid found a video he wanted to watch about an old truck, turned out it was Luke installing one of these on a old truck.
thecarbcheater.com/Install.php
Interesting theory, I am still checking it out but it kind of reminds me of the metering system they used to have on the old feedback carbs to adjust fuel mixture or the metering block people would make when the durasparked but with probably better electronics controlling it.
Really neat thing if things go sideways on the road, a vacuum cap and it is business as usual.
But of course off camber stuff would not be improved at all (but then I haven't had any issues with it yet...)
RaceRanger97
December Truck of The Month
Vagabond Video
25th Anniversary Merch
TRS-3 Ford Ranger Sponsors
