Kags101
- Aug 30, 2022
- 8
- Calgary, Ab
- Ford Bronco II
- Engine Type
- 2.9 V6
- 2WD / 4WD
- 4WD
- Total Lift
- 4"
- Tire Size
- 31x10.5
Hello all, i know there is lots out there about this swap, including technical articles, but what I haven't found, is a definitive parts list. This weekend im out to the wrecking yard, as there is a freshly dropped off 1994 explorer. yes i know 95 had discs, but im not gonna pass up the 94 and chance it taking years for a 95 or newer to come by. So, since its there, im going to grab the D35 and 8.8 rear end. does anyone know exactly what all i need to take from the sploder? My bronco is currently stock height, with U joint style drive shafts. I will be lifting the truck with a 4" suspension lift at some point( i understand that i cant use the RC lift with a D35?) I understand as well that if i d35 swap before i lift i have to shorten the drive shaft, but allegedly it should work with a lift without modification. those details dont matter as i will cross that bridge when i do the swap( probably in the spring as this is my winter "beater" and im not about to take it out of commission this close to Canadian snow fall.
Long story short, im not 100% on how much of the exploder to take., full rear axle with brakes, easy. should i take the rear drive shaft though? on the front, is it just the beam with the front diff on it, or do i need both beams, and radius arms, and brakes, etc. if there is a thread with all the detail on stripping the donor, i apologize, but i haven't come across it yet. and as im hitting the junk yard by sunday, i need quick information. thanks!
