Exhaust leak
9723
64
XLT
2.3
..been hearing an exhaust leak where the manifold connects to the catalitic converter section. Took it apart and I see no decernable reason it should be leaking. No bending or warping, no corrosion to speak of.
Only two reasons I can think of:
1. It just needs to be aligned, reseated and torqued evenly.
2. The catalitic is clogged enough to force blow-by thru that fitting.
The '97 has no gasket there and the manifold is a true header (steel tubing) from the factory, and hard to find.
I'm hoping someone has been thru this and has some info....
Thanks!!
9723
64
XLT
2.3
Fixed, no more leak....
I fixed it....took it out, lightly hit it with 000 steelwool, put it back in.
I was very careful to line it up snuggly and straight, then I hand tightened the two bolts to the manifold, checking to make sure they were each (on the flange) the same distance from the manifold. Then I torgued each at the same time, starting at 30 lb/ft, then 35, 40 and 45. Tightened the back to the muffler and no more exhaust leak.
I also soaked ( in liquid wrench) and put the wire brush to all the bolts.
