wynnespeed
- Jul 9, 2013
- 0
- GA
- 1995 and 2000
- ford
- Engine Size
- 2.3 and 4.0
back in Dec. i couldn't figure out why my 2000 4.0 ranger wouldn't stop bucking... well it turned out i had a bad head. so i got this 4.0 from a 92 explorer (that my buddy had) and started the swap. turned out i had to use the 92 flex plate and had to mod the driver side engine mount bracket. also i used the 2000 upper and lower intake (with all new gaskets) so all the vacuum and sensors wound match up. i had to take the cam shaft pos sensor assembly out off the 2000 motor and put it in the 92 motor because it only had an oil pump drive gear thing instead of the csp sensor. anyway its now all put together and hooked up. and i will turn over but it seems like its trying to fire and wantiNG to run but it just wont. i know i got good fuel pressure.
any help would be highly appreciated since i need the truck on the road asap
THANKS
THANKS
