- Aug 17, 2007
- 4,441
- central ohio
- ford/escape
- Engine Type
- 2.5 (4 Cylinder)
- Engine Size
- 2.5/151 I-4
- 2WD / 4WD
- 2WD
- Tire Size
- 235/70/16
- My credo
- the grey-t escape
Well just dropped off the 2011 awd escape for a diagnostic, Im thinking its wheel bearings, specifically the rear. has a rumbling noise above 35 and really sounds scary at 55. Odd thing is it started all of a sudden. Saturday we were coming home (about 40 miles away at that) down a unfamiliar back road, I hit a big bump in the road that I didnt see, at speed. may have got air time, idk. Thats when the noise started. I was worried it wouldn’t make it home. It did though. jacked up each end at at time, theres some play in the back wheels, none up front except for my left front tie rod. Rear diff full of oil though I see where right side halfshaft seal is leaking. Looked up utube videos, saw tools I dont have & my compressor isnt big enough to support a impact. As much as I hate to I think its a good move to let someone else do it, my luck Id get it half apart and be stuck- with it tore half apart and not moveable. Wish it had hub-unit bearings like the front of a S-blazer or honda uses. But nope, really cussing the fully independent rear now, my solid axle 4.10 in the ranger has over 200K with original bearings. Guess I wait on that phone call for a verdict. I know this setup would need bearings eventually, at least the fronts I can get a complete knuckle/bearing/hub assembly.
One really weird thing, on the way into town the noise just stopped for no reason, at 55. but once I was in town it was there rumbling at 35.
