Engine won't stay running.
Range98
Pennsylvania
306 with a bunch of mods
Got the engine all hooked up a few days ago and it fired in half a turn but it will not stay running. It starts perfect but when it starts coming down in the rpm's it stalls out every time. I checked fuel pressure, vacuum lines, my coil pack, and the timing was at 8 degrees. I'm running out of ideas. My next leads are my crankshaft position sensor or my MAF. When I give it just a tiny bit of pedal it will idle but is VERY rough and feels like a timing problem. It has very slow throttle response and surges. Any ideas out there!? 1997 mountaineer engine into 1998 ranger.
snoopjonnyjon
01/2013 STOTM Winner
MTOTM Winner
Saskatoon, SK
306
Not sure if this is your problem or not, but when you first turn the key on, the fuel pump runs for 3 seconds and then shuts off. After that, the ECU requires a signal from the distributor to continue running the pump. If there is something wrong in that circuit, the truck will start, but will not continue running.
Range98
Pennsylvania
I checked fuel pressure during the stall and it was fine.
Range98
Pennsylvania
well I was out all afternoon and I discovered my spark plugs are firing very sporadically and at different speeds. I'm replacing the crankshaft position sensor tomorrow hopefully that will fix it.
Range98
Pennsylvania
not the crankshaft sensor. I'm clueless
Range98
Pennsylvania
I've tried I bought a scanner and the computers not throwing any codes.
doorgunner
Lab Rat for V.A. hospital
MTOTM Winner
2009 Truck of The Year
516
New Orleans (8' below sea level & sinking)
350+1
N/A
3/4
23570R15
JESUS Loves Ya!
hope you figure it out (stuff like that is why I have a carb & distributor on my ngine now)
hoosier1104
I'm Awesome!
MTOTM Winner
104
Camby, IN
302 based goodness
Work hard and play harder
Your last sentence does not make sense logically. The crankshaft sensor should not control duration of spark. I would look at your coil pack, that connection, plug wires and the plugs themselves.
Rowdy Fitzgerald
Hog hunter
Firefighter
EMT / Paramedic
372
Nevada
5.0,4.0
Solid Axle Swap 4x4
6”
Possibly the module on the side of the dizzy? Maybe it just needs to be cleaned and new dielectric grease put on?
Range98
Pennsylvania
i took a vacuum pressure gauge and found when it stalls it's at not even 2 lbs. I started searching for big vacuum leaks and found one right after my throttle body. Half the gasket is missing so I have that all apart and going to seal that and see what happens. Not sure on timing anymore. Going to get vacuum pressure up and go from there
Rowdy Fitzgerald
Hog hunter
Firefighter
EMT / Paramedic
372
Nevada
5.0,4.0
Solid Axle Swap 4x4
6”
There's your problem! I'm betting that'll fix it.
Range98
Pennsylvania
I'm hoping! We'll find out in about an hour I'll let ya know
Rowdy Fitzgerald
Hog hunter
Firefighter
EMT / Paramedic
372
Nevada
5.0,4.0
Solid Axle Swap 4x4
6”
Kirby N.
March Truck of The Month
