Engine whistle after intake R & R
vwnut
Wellington, Nova Scotia
Mazda
I've been chasing a suspected vacuum leak for some time on a 1999 3ltr.
I removed the upper intake manifold thinking maybe the pcv hose was cracked and leaking.
The hose was ok. Now after replacing the intake it has developed a whistle/chirp when I bump the throttle quickly off idle.
It sound like it's coming from the rear of the engine towards the drivers side. Any thoughts?
rusty ol ranger
2.9 Mafia-Don
8,549
Michigan
177 CID
Spray some ether around where you mated the intake. See if the RPM's increase a bit.
Sounds like the intake didnt seal well.
vwnut
Mazda
The idle remained the same after replacing the gasket.
Wouldn't the idle increase some if the gasket didn't seal?
rusty ol ranger
2.9 Mafia-Don
8,549
Michigan
177 CID
Depends how bad the leak is.
Did you also remove the throttle body? Could be the gasket on that.
vwnut
Mazda
The throttle body stayed on. Just unplugged the sensors and flopped the manifold over to avoid draining off some coolant.
It seems to be quite a loud whistle/chirp to be a small leak.
Curious Hound
Formerly EricBphoto
TRS 25th Anniversary
18,671
Wellford, SC
6"
Are you sure it’s not the cam position sensor shaft squeaking? That would be more chirp than whistle. But, I haven’t heard your noise.
rusty ol ranger
2.9 Mafia-Don
8,549
Michigan
177 CID
A smaller leak will usually whistle louder as the air is being sucked through a smaller hole
stmitch
March 2011 STOTM Winner
MTOTM Winner
2011 Truck of The Year
690
Central Indiana
Yep. Cam synchro is at the back of the intake and likes to chirp/squeal when it loses lubrication
SenorNoob
1,011
Middle Tennessee
1.5" Front + 4" Rear
245-70-R16
Is it possible it's not leaking into the intake but out underneath? I know I misunderstood the directions with my first intake gasket. It said to put sealer in the corners. At least on the 4.0 it has to go all the way across the block surface.
vwnut
Mazda
I didn't get into the lower intake gasket; just the upper.
Should have been pretty straight forward
pjtoledo
3,389
Toledo Ohio
Fords
3.0 2.3
inspect that hard rubber hose under the intake to the PCV
Rick W
October Truck of The Month
25th Anniversary Merch
