2.3L ('83-'97) engine swap 2.3 to a 2.5 lima
scottobr
maine
ford ranger
i have a 97 ranger with a 2.3. i found a lima 2.5 out of a 98-99 . engine is out but has been sitting at a junk yard in a box trailer for about 7 years, low miles, can anyone tell me if both engines are the same? as far a block bolt pattern to 5 speed manual transmission
6,598
Yes, you can do that swap, both blocks are the same so trans will bolt up
Yes, you will need to swap over intakes so 1997 wiring harness and fuel lines will match up
You don't need the 2.5l computer, and don't want it because of fuel system differences
1994 and earlier 2.3l were different, can't do that swap
scottobr
maine
ford ranger
thank you i read the 2.5 fuel psi was returnles so i knew about the intake. and exhaust manifold off the 2.3 since it's headers is a better choice, i just saw a lot of shit on the engine .ac comp i don't need, and stuff he wants 300$ for the engine any thoughts? no idea on miles on engine,
6,598
Value of used parts is decided by the BUYER not the seller
Asking price is just that,"asking"
It could be a GEM or a TURD, its not a piece of glass where you can see the cracks, lol
If its been sitting for 7 years then seller either doesn't care to sell it or doesn't need the money
Make an offer YOU feel good about
Master rebuild kit for 1997 2.3l is $500 or less
So for $200 more(over asking price) you could have a NEW 2.3l
$300 seems high, especially if its unknown miles and you haven't seen it running, but you want it not me, lol
scottobr
maine
ford ranger
yeah not many options right now , it's our only truck and money is tight, we bought our ranger 6 years ago , kid over heated it and cracked the head, i put a junk yard head on it and its always ran fine, but has a slight tick, well tick is now a knock on cyl no.1 unplug injector it goes away so pretty sure it's a rod bearing
6,598
Yup, good diagnoses
blitz67
Interesting to hear about this swap. I'm going to have to look into this some more. Plus, I'll have to score a 2.5L engine.
Thanks for another idea and possible project. Hahaha. Already have 4.
tinman_72
118
North Georgia
2.5 (4 Cylinder)
2.5
Factory
None
255/60R15
RoHS compliant
scotts90ranger
2,671
Dayton Oregon
2.3 Turbo
By "can't" I'm sure he means it isn't "simple" :), anything's possible, just depends on how crafty you are, I have a '89-94 crank sensor setup on my '86 block... now putting a '95-01 Lima block in an '88 or older would be some work, would involve DIS of some form or something odd...
Carlisle Truck Nationals
Join us at the Carlisle Truck Nationals for the 40th Anniversary of the Ford Ranger.
