RegularGuy
- Apr 20, 2020
- Reaction score
- 38
- Location
- Belingham, WA
- Make / Model
- Ford Ranger
- Engine Type
- 4.0 V6
- Automatic
- 2WD / 4WD
- 4WD
2007 sohc fx4
The truck lacked of power up until I replaced the battery on the 2nd (related? Idk). Now the power is great but after about 20 minutes when the engine warms up, the engine appears to momentarily die before it catches itself. One, maybe two cylinders in a row spaced out 10-30 seconds, sometimes up to three times back to back....
The engine does exactly the same thing at idle so I doubt it's fuel related. When driving down the highway, it feels like someone has momentarily engaged trailer brakes. The truck suddenly slows down a little then the power comes back
The engine does the same thing regardless of electrical load, lights, stereo, fan
A list of things which come to mind:
My A/C is likely low on the cool stuff
Spark plugs, wires, and coil are of an unknown age... They could potentially be cracked
The power cable for the subwoofer is run against the harness coming through the firewall below the steering wheel (same issue with stereo off though)
Where should I start for the sake of time/money saving purposes? Check engine light isn't on, if it was my first guess would be a misfire code
