MarkusMcBride
- Aug 18, 2015
- 9
- Western Canada
- Ford
- Engine Type
- 2.9 V6
- Engine Size
- 2.9
- 2WD / 4WD
- 4WD
Hi again, I'm back a year and a half after rebuild motor and tranny (rebuild February 2020) in my 87 2.9L 4x4 ranger.
This truck is my daily and it will be moving me and all my worldly possessions across 800km of mountain ranges and rolling plains in 2 weeks time. I will start a new job then and won't have as much time to work on it. I need to solve this damn issue NOW.
I fixed an issue I'd been having last night more on that below. There is still one bug that has been haunting me for about 1.5 years now. It got really bad before the rebuild, and afterwards it was better but never gone. What happens is the motor will cut out completely for a split second under load and does it more often when there is a voltage demand. It's worse at night when I have the headlights on.
Example: I'll be going up a hill at night, highbeams on, and then honk the horn and it really starts doing it. The engine is sputtering and bucking like the coil is sending intermittent power. I did this to test my theory that its worse when there is a greater voltage demand. When it cuts out it is a sharp cut out, not a hesitation.
It is not restricted to the horn. Or even to the headlights. Could be day time and it could happen under load just going up a hill though it is more likely to occur with heavier voltage demands.
I am going to try swapping out the battery today to see if theres any improvement there.
The issue existed before and after these improvements:
The black "single function fuel reservoir" on the frame. Now I tore through this forum and others to educate myself as much as I could before tackling it and some people say there was a filter in the reservoir in 87's and some say no filter. There is an inline filter already after the HP pump on the frame which I changed. Well, there is also a cartridge filter in the reservoir and it was dirty as hell. Changed it out, reinstalled the reservoir and she'll sing up to 5000rpm now. Not that I take it there too often but when I'm pulling a trailer with 2 motorcycles in it through mountain passes up here in British Columbia, I do need to be able to hit 4k and then some from time to time. (I need to move across the province in 2 weeks). So, for anyone who is experiencing what appears to be a fuel shortage under load, make sure you check that reservoir for a second filter. If the engine had light loading for a bit, the LP pump in the tank would have a chance to pressurize enough fuel passed the filter so that I could hammer down temporarily but not for long before it was struggling to keep up.
One problem down, one to go. Any thoughts, feedback, troubleshooting tips are welcome. @PetroleumJunkie412 you still on here? I was skimming through our last correspondence and next thing I knew I was scanning ebay for a cosworth 2.9. Maybe one day. I do think if I get to the bottom of the above issue I'll at least order some pacesetter headers and pull them awful manifolds off.
Here she is:
- Alternator is new
- This started around the same tie my gas gauge quit working, not sure if they're related but:
- new HP fuel pump, new sending unit, gas gauge still does not work
- New TPS and harness
- New coil, plugs, wires
- New dizzy with Elec ignition module mounted to it
- New ECU computer for an 88
- Deleted the EGR
- I've been over the grounds and I've installed extra grounds as well but who knows
- New IAC valve
- New MAP
Here she is:
