Engine crossmember
ThatGuy
11
Oak Ridge, TN
I'm thinking about lowering my Explorer down a few inches. I want to run some super soft springs plus get my COG lower. The only problem I'm seeing is the engine crossmember. Have any of you cut the x-member out? I was thinking of cutting the bottom off and running a piece of 1/2" directly across the bottom of the oil pan.
I will limit my uptravel to approx. 3" and let it have all the droop it wants. Gonna be running air bumps to control the travel. I plan to take out quite a chunk of sheetmetal. I will be installing the 4-link rear in the spring so I want to get all of this done soon. The engine crossmember is the only thing holding me back right now. Just wanted to see what others had done.
RangerSVT
Oct 09 OTOTM
ASE Certified Tech
53
TRS since 2002 - NW KY
GT-40 5.0L EFI W/AC
When I do my SAS soon, I was planning to cut the X-member out and make a custom oil pan-hugging X-member that is removable on the bottom side just in case I need to remove the oil pan for any reason...but I think it's a good idea...
SVT
ThatGuy
11
Oak Ridge, TN
Removable sounds good. Will look into this when I get some free time this week.
The_Dealer
10
Macon, GA
Duh!
cut it and weld a flat piece of 1/4" across it. kinda like stock but "high clearance" from the underside
ThatGuy
11
Oak Ridge, TN
That's what I was gonna do but with 1/2" instead. The engine crossmember is the strongest part of the whole truck so I want to keep the integrity, just make it hug the engine a lot closer.
RangerSVT
Oct 09 OTOTM
ASE Certified Tech
53
GT-40 5.0L EFI W/AC
My plans are to use 1x2 tubing, this has more strength torsionally and is lighter than 1/4" flatbar, but 1/2" would probably work...
SVT
crawlin91
60
Crawlorado
2.9, 4.0
my plans are to cut it off weld in some 3/8 underneath the motor mounts and connect the two with a piece of tube. Maybe Ill get fancy and add some speedholes.
