jason.1224
- Dec 16, 2015
- 0
- ford
I'm new to the site and i am in desperate need of some help.
Next week i will be traveling home to see family and to do an engine swap in my old ranger in Hawaii. My truck is a 1993 ranger 4x4 3.0 with a manual trans. the engine has seized after 378k miles and i was unable to source a used engine from a similar year to replace it with. The only 3.0 that i could find was a 2007 out of a ranger with a manual trans. The 2007 engine is ohv i have the engine harness and i believe the pcm but that is it.
My question is what is the best way to go, convert and make the 93 an odb2 system using the harness and pcm from the 2007? If so what exactly does that entail? Option 2 would be to strip the new Engine down and put all of my old sensors on and use the 1993 distributer in place of the CPS (gear teeth are the same, just note sure if it would work just swapping it and not using the coil packs) ,or is there another solution that i havent thought of? Any help would be greatly appreciated. thanks in advance!
