Natedog
- Aug 7, 2007
- Reaction score
- 5
- Location
- CA
- Make / Model
- Ranger
- Manual
Last night on the way home my Ranger started running poorly. At low speed in the parking lot (in first or second gear) and then later coming to a stop in second gear at a stop sign, it started kinda bucking. The engine started jerking back and forth like if you were constantly on and then off the accelerator. The closer I got to home, the worse it was running and I saw the check engine light blink on and off several times.
When I pulled into my driveway I side-stepped the clutch and smoked both rear tires. I set the e-brake, popped the hood, and jumped out to look at the engine. After idling widly for about 30 seconds between about 600rpm - 1500rpm, the engine died and wouldn't restart. I could hear the fuel pump relay clicking back and forth alot when it died and just after. Then silence. When I turn the key to 'run' position I don't hear the fuel pump run like it should. It just cranks over and once or twice kinda barely tried to fire up. Mostly just cranks endlessly. I swapped out the fuel pump relay with a good used one and no difference (this relay is off my parts truck that ran when it was parked).
Hooked up my code scanner and got nothing with KOEO! Tried several times and nothing. Won't start, so cant do KOER tests. It was late and dark out, so I just parked it for the night and took the other car to work today.
I'm thinkin frame rail mounted fuel pump, fuel pump relay, fusible link? Suggestions please?
