aball4620
- May 13, 2020
- 3
- Seattle
- Ford Ranger
- Engine Type
- 2.9 V6
- 2WD / 4WD
- 4WD
I've been having massive issues with my '88 2.9 since replacing a head gasket. Super rough idle, doesn't like to rev above 2k, moderately low fuel pressure at ~29psi that won't hold with engine off, and basically not driveable. I've run through the fuel pumps, injectors, FPR, TPS, and pretty much everything on the truck besides the computer. I finally decided to get the wire piercing probe out and check the computer. I first wanted to confirm continuity between the TPS and pin 47. TPS is between 0.86-4.55 with no jumps, and pin 47 is 0.82-4.52 with no jumps. Seems good (code 63 is the only code this ever throws and it is only in the continuous memory). Pin 8 from the fuel pump relay shows KOEO 0.0 and KOER 14.3v. Pin 22, however, also to the fuel pump relay is showing KOEO 12.02 and KOER 1.14v..... my understanding is that pin 22 is at 12v (or 14 with the alternator?) with the key on. Full stop.
Could this be showing a bad computer? Every time I bring it up it seems I'm told that these things rarely go bad and that it must be something else. Are there any other tests on the computer I should be running?
