Welcome Visitor! Please take a few seconds and Register for our forum. Even if you don't want to post, you can still 'Like' and react to posts.
Why do you say not to use a tstat?Oh, and if you want pics on where to put the switch and wires and stuff, pm me and I can shoot some stuff to you. It is not that hard. Just dont use a t-stat. Use a switch.
Sounds like quintessential 1970's high performance advice. We've come a long way since then. There is no reason to get rid of the thermostat. And I would wire it up with a cheap, readily available temperature probe based relay kit. A switch is usually just a cheap, easy way of making something "just work".Why do you say not to use a tstat?
ircm........damn dirty ape things they are.Only problem I had with an electric fan (on my Tempo) was that it kept blowing the little whatchamacallit (the word actually escapes me right now) and the fan would not work...ended up cracking my rad twice for that...
I've been considering it for this truck but have already cracked the head once (forgot to remove the cardboard covering the rad in winter when it got warm) and don't like the cost of repairs...
I like the idea of having an led indicator though...that would help...but it would have to be at eye level because when my truck overheated and cracked the head the temp guage was working perfectly and showed the overheat...I didn't see it...
