Electric fan conversion question
n8tyfour
Temecula
Ford ranger xlt
Hey guys I got an electric fan conversion kit that comes with the screw in temp switch.
Where would you screw the temp switch into?
Thanks!
Uncle Gump
Token Old Guy
13,457
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Use a hose adaptor... that will be the easiest.
32mm Water Sender Hose Attachment Radiator Adapter Sensor for Water Coolant Temp Gauge Temperature Meter Sensor with Hose Clamps https://a.co/d/48HVooN
ericbphoto
Overlander in development
16,593
Wellford, SC
6"
Yup. What he^^^ said.
Uncle Gump
Token Old Guy
13,457
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Thanks!
Double check your hose size. Also with a single wire sender... the adaptor needs the ground lug. I think you will be 1 1/2 hose. The one I posted is to small if your hose is 1 1/2.
ericbphoto
16,593
Wellford, SC
6"
And will need a wire run from the ground lug to the frame or engine block for it’s ground connection.
n8tyfour
Temecula
Ford ranger xlt
I think that's why the kit includes the bung type, to ground as well.
What do you guys think about the radiator probe type?
ericbphoto
16,593
Wellford, SC
6"
Lot's of people use them. My preference is to have the sensor right in the coolant. I don't like poking around delicate radiator tubes and fins. But that's just me.
n8tyfour
Temecula
Ford ranger xlt
That's an excellent point. I just replaced my radiator to a champion and so that's exactly what I'll going to do. Really appreciate the help!
