ecm controlled fan
felgar_1
6
farmington, il.
ford ranger
2.5 and 3.0
2" on the 2000
6" on the 99
255/45r18
drive like you stole it
i have a 1999 ranger with a 3.0 and am tired of replacing the temp controller (aftermarket) and am trying to see if i can make it to where the ecm controls it. i know the taurus ecm controls the fan but can't find enough info to do it. has anyone done this? i can turn things on and off in the ecm.
Blmpkn
Toilet enthusiast
7,339
Southern maine
Ford Bronco
2.3 EcoBoost
2.3
2.5"
The tuarus ecm NEEDS to control a fan, since it's motor is plopped in the engine bay the wrong way to utilize a mechanical fan.
Rangers never came with an E-fan apart from a supplemental one that only comes on with the a/c.. if equipped.. and that might only be with the 4cyl trucks..
There might not be a way to do it without the aftermarket controller. Are the controllers you've been purching of quality.. or are they the cheapest option of off ebay/amazon?
bobbywalter
TRS Technical Staff
Ugly Truck of Month
TRS 25th Anniversary
5,568
woodhaven mi
FORD mostly
BIGGER
sawzall?
might be able to segment swap if the hardware is there. or just turn it on depending on what tuner you have
bobbywalter
TRS Technical Staff
Ugly Truck of Month
5,568
woodhaven mi
FORD mostly
BIGGER
sawzall?
i just tend to use the 5 to 15 dollar 3/8 pipe thread switch threaded into my t stat housing to run the lincoln intech controller..
felgar_1
6
farmington, il.
ford ranger
2.5 and 3.0
2" on the 2000
6" on the 99
255/45r18
i have had the cheap ones to the 100 kits and they only last a few years before they act up and if i can get the ecm to do the job it will be alot cleaner install and i like setting when it comes on. i have sct software so i can change alot of stuff in the ecm. i already have to tune the ecm.
Curious Hound
Formerly EricBphoto
18,797
Wellford, SC
6"
I use a switch in the radiator hose to control the fan relay directly. No other controller needed. Mine has been working for years with no problem, except that my relay and base melted last week. But that’s because it was a cheap relay with too low of a current rating.
bobbywalter
TRS Technical Staff
Ugly Truck of Month
5,568
woodhaven mi
FORD mostly
BIGGER
sawzall?
what i use.
6 or 7 years current system that takes hellacios ass whoopinzz. only issue is its 165 cut off. so the fans run longer than needed.
now..for you Eric..you run two cheap 30 or 40 a relays in parallel and that won't happen.
bobbywalter
TRS Technical Staff
Ugly Truck of Month
5,568
woodhaven mi
FORD mostly
BIGGER
sawzall?
well....have a look. might be pretty simple.
Curious Hound
Formerly EricBphoto
18,797
Wellford, SC
6"
what i use.
I can always find a relay that will handle the load.
bobbywalter
TRS Technical Staff
Ugly Truck of Month
5,568
woodhaven mi
FORD mostly
BIGGER
sawzall?
yeah. those too.
felgar_1
6
farmington, il.
ford ranger
2.5 and 3.0
2" on the 2000
6" on the 99
255/45r18
i used one of those for a f550 to run the air ride comp. and smoked it in 10 minutes. i will have to get it working for my tuning so i will put it on a switch tell i figure out how i am going to do it.
Rick W
October Truck of The Month
25th Anniversary Merch
