Easy v8 swap?
Reaper1354
Vineland NJ
Trying to go for a swap that will be easier to do. What would be the engine that needs less modification to fit my 97 4.0 ranger? It's rwd and AOD. Maybe the 4.6 or 5.0? I'm looking for something that will give me the power I want but won't make the gas mileage do terrible. On average I'm getting around 18ish and it'd be more cost efficient to just do the swap instead of wasting money in the 4.0s I hear. Don't mind if I get an average of 16ish at worst, just looking for an achievable 300 hp without needing major modification to the engine. Also, would I be able to use the stock transmission or would I need a different one? Trying to just buy the engine but if I need both I'll simply buy a donor car. I appreciate any help.
Edit: I am using this ranger as my DD at the moment and I plan on keeping it that way so I'd prefer something that isn't too crazy and is still fairly reliable. Thanks
Rock Auto 5% Discount Code: 81874766E40C6A 5th, 2022
dangerranger83
5.0 HO under the hood!!!
54
Lafayette, IN
5.0 HO carbed with an np435 and np208
You won't be able to keep your ranger trans. A 4.6 is a very tight squeeze and takes allot of time to get it working in a ranger because of all of the wiring, not that it's impossible to do.
Here's a link to articles in our tech library about doing a 5.0 swap. The articles are at the lower left side under engine rebuilds/swaps.
http://www.therangerstation.com/tech_library/index-engine-fuel.shtml
Sent from my SPH-L710 using Tapatalk
Reaper1354
Vineland NJ
I saw that he has an electric fan instead of the stock one, I'm assuming that would be required for me to fit the 5.0?
dangerranger83
54
Lafayette, IN
You can probably fit a mechanical fan but it's a common practice to go with an electric fan as it puts less drag on the engine and frees up a few HP but also running an explorer Front End Assessory Drive (FEAD for short) helps gain some clearance. I'm running a 3.8 Taurus fan on a 3 row explorer radiator and it keeps my 5.0 cool (don't know how cool because I haven't gotten to replacing my temp gauge). The fans move enough air to keep a big block cool. I only run mine on low and that moves about 1800cfm of air a minute, the high setting moves 2800 cfm a minute but don't run both at the same time, can burn up the motor. I also don't have my high hooked up to run but will make it so that I can turn it on via switch in my cab but the low turns on/off by itself via temp sensor.
Reaper1354
Vineland NJ
Thanks I appreciate that. Out of curiousity, with the 5.0 trans and engine in my 97 ext cab 2wd ranger, would I use the 4.0
Driveshaft or the 5.0 driveshaft, or would I need to get a custom size one all together?
