easier way to drop rpms
jax4bangin
WESTMINSTER CA
2.3
hey guys, iv got a new solution to the hanging rpms without even messin with the idle air solonoid.. when u take off ur intake tube u will notice right at the bottom left of the throttle opening there is a port that lets air into the idle solonoid. i shoved a piece of rubber into the port to limit how much air can get through.. i am getting symilar results of running a restrictor plate but i think that this new method will not trip the engine light.. i will run it for a few more days and let u know if i get an engine light or not
jax4bangin
WESTMINSTER CA
2.3
well been runnin this set up for 4 days now and no engine light.. if u have a manual tranz 2.3 duratec and dont like having to wait for several seconds with the clutch in to make a smooth shift, i wud highly recomend givin this a try
Wicked_Sludge
43
Westport, WA
3-point-GO
shoving foreign objects in the intake is a very bad idea :icon_surprised:
jax4bangin
WESTMINSTER CA
2.3
yea i was kinda worried bout it getting pulled into the manifold but its pretty dam wedged.. its really hard to get it out.. its workin pretty well for me
Wicked_Sludge
43
Westport, WA
3-point-GO
until it gets hard and brittle from repeated heating and cooling and starts to spit dry-rotted chunks of rubber into the cylinders :icon_thumby:
jax4bangin
WESTMINSTER CA
2.3
oooooooo very good point. well shit man. this stupid hanging rpm crap is really pissin me off. when runnin a restrictor plate that brings rpms down at a more normal rate, it throws an engine light and sometimes has trouble starting
Wicked_Sludge
43
Westport, WA
3-point-GO
drill a larger hole in your restrictor plate.
the hose is doing the exact same thing as a restrictor plate. if the hose works, there should be absolutely no reason a plate should work. its just a matter of tuning it to function like you want it to.
jax4bangin
WESTMINSTER CA
2.3
man iv made 8 different plates.. iv got some that dont throw a engine light but dont bring rpms down fast enough.. for some reason the piece of rubber isnt setting off a light.. i have no idea why it wouldnt throw a code, maybe cause its further away from the solonoid?? i have no clue.. could a tuner address the problem?
Wicked_Sludge
43
Westport, WA
3-point-GO
im sure if a guy really wanted to get into it he could design a tune that brought the idle down faster...but thats an aweful lot of work for something thats little more than an annoyance :dunno:
jax4bangin
WESTMINSTER CA
2.3
yea i hear ya.. but man it really makes it a pain to drive wen u have to wait 5 seconds between each gear.. its either that or slip the clutch to bring it down(cant be good for that clutch).. i think im going to try a piece of rubber from a dirt bike tire to stuff the port..
