benhojo
- Dec 10, 2012
- Reaction score
- 0
- Location
- Michigan
- Make / Model
- Ford
- Engine Size
- 2.8 v6-351w someday
- Automatic
OK, Have a 83 ranger with 2.8, just did duraspark conversion and installed holley 2 barrel. Can't get the truck to fire up. thought it was a flooding issue, but cleared all cylinders with blow gun and still won't fire. Cranks over just fine, was getting a spark when took plug out. Any suggestions? Also on the duraspark page it says connect the coil to the red/w green line wire or the brown/pink line wire, my truck being 30 yrs. old you can imagine the wires are pretty faded and i just hooked coil up to one of wires with 12 volts when in on position. Can any one confirm what position in the connector it should be spliced.
