ronmsal78
- Jun 27, 2011
- Reaction score
- 0
- Location
- Kentucky
- Make / Model
- Ford
- Engine Size
- 2.3l
- Manual
I have a 2003 Ranger 2.3l manual trans. I cannot keep the check engine light off. I have already done the cheap/easy stuff. I cleaned the MAF etc., I also checked for vacuum leaks... none. Since my scanner can only give me freeze frame data, no live data. I cleared the code and found that the code always set at one particular time... Starting in first gear. Here is the F.F.
Exactly as written on scanner:
CODE P0171
FUELSYS1 CL
FUELSYS2 NA
LOAD_PCT% 18.8
ETC(Deg F) 203
SHRTFT1(%) 14.1
LONGFT1(%) 24.2
RPM 890
VSS(MPH) 6
SPARKADV(Deg) 16
IAT(Deg F) 102
MAF(lb/min) 0.270
TP(%) 16.5
O2B1S1(V) 0.215
SHRTFTB1S1 14.1
O2B1S2(V) 0.000
I have a really good question about the above info. Why on God's green earth is the engine running (or trying to run) in closed loop during take off? I always thought accelerating was accomplished using open loop strategies.
I need some insight on what exactly is going on here. It makes no sense.
Any help is appreciated, Ron.
CODE P0171
FUELSYS1 CL
FUELSYS2 NA
LOAD_PCT% 18.8
ETC(Deg F) 203
SHRTFT1(%) 14.1
LONGFT1(%) 24.2
RPM 890
VSS(MPH) 6
SPARKADV(Deg) 16
IAT(Deg F) 102
MAF(lb/min) 0.270
TP(%) 16.5
O2B1S1(V) 0.215
SHRTFTB1S1 14.1
O2B1S2(V) 0.000
