dual gas tank ranger? is it rare?
That_4.0_ranger
152
Appleton,W.A.
4.0, 2.9
stock
31x10.50-15
so i was at my neighbors house and he has a gen 1 ranger standerd cab long bed with dual tanks he said i can have it if i want it, but i was wondering if thats rare at all its not an stx or anything its just an xlt with a 2.9 so beyond the tanks its nothing special but i was just curious.
dvdswan
2,899
Seattle, WA
Ranger XLT 2WD
Rare is a term used a lot by sales to grab someone's attention.
As far as the dual tanks, it was an option for only a couple of years IIRC. Certainly, not common. Rare, meh. I don't know the exact numbers produced but a 65-67 Ford Cobra with a 427 only produced like 350 total. That's RARE. Hence, the $1M price tags.
Junk Collector
4,704
Rapid City SD
Definitely not rare. I've had a bunch of them. Many 1st gen trucks had them, I don't think it was an option after 1988.
Dual tank extended cab trucks are kinda uncommon.
superj
2,502
corpus christi, texas
ranger edge
3 liters of tire smoking power
none
none
235s
Grew up in the 70s, 80s, and 90s
i wish this 04 had dual tanks. that would be cool to have a little reserve tank like an f150
alwaysFlOoReD
5,031
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
I have an 86 extended cab with dual tanks. I believe it was available for a couple years. The rear tank takes the place of the underbox spare tire carrier.
That_4.0_ranger
152
Appleton,W.A.
4.0, 2.9
stock
31x10.50-15
i considerd making my 91 extended cab dual tanks because i took the spare tire rack out and i have an extra tank out of a 1990
Craig0320
225
Mississppi
Break it right the first time. Fix it better the next time.
My father in law had a 93 with dual tanks.
8,296
The required EVAP systems killed dual tanks, drives the cost up ALOT
Dual tanks in general are rare on any vehicle after 1988 or so because of this
But its not "rare" as far as demand because not many people wanted or needed dual tanks
In fact people with the older dual tank vehicles will often disable one tank because of problems with the "plumbing", lol, and convert it to single tank operation
So you will often come across dual tank vehicle but only one tank is usable
Some states also have Fuel Capacity limits now on vehicles, i.e. gallons of fuel limits vs weight of vehicle
racsan
4,317
central ohio
ford/escape
2.5 (4 Cylinder)
2.5/151 I-4
the grey-t escape
I thought about cutting out the fuel door out of my ranger trailer & welding it in to my ‘94 bed for that “dual tank” look.
alwaysFlOoReD
5,031
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Iirc all the beds still have the inside bump for a second fuel filler line.
19Walt93
4,412
Canaan,NH
351
3"
235/55R16
We sold a few dual tank Rangers back when people didn't have to get a loan to afford over 40 gallons of gas. To me it's a useless option, I have to pee before I use up my 17 gallons anyway. By the way, you guys have Supercabs, not extended cabs if they're Fords.
racsan
4,317
central ohio
ford/escape
2.5 (4 Cylinder)
2.5/151 I-4
the grey-t escape
I traded in my ‘88 ranger for a 3/4 ton that had a single 40 gallon tank, after 4 years and only pulling a travel trailer a couple of times I traded that 14 mpg truck in on the ‘93 ranger supercab I had. Now Ive got a ‘94 2.3 2wd longbed with a swapped in 20 gallon tank, gets 21 at best, cant imagine daily driving a V8 now with a big tank, the 20 gallon 4cyl is bad enough to feed. strangly enough the hhr with essentially the same size engine (but dual overhead cams) gets 5 mpg better than the ranger, has a 14 gallon tank and I can go for 2 weeks easily before refueling.
Roert42
4,891
Kintersville, PA
Ranger XLT
4.0 SOHC
The hhr is probably more aerodynamic, even marginally. If it’s front wheel drive that’s the big thing, even with an auto they are so much more efficient then rwd.
Have a ‘00 mustang with a 3.8 manual, low 20s highway.
Had a ‘01 MonteCarlo with a 3.8 auto fwd, 30 mpg highway.
Roert42
4,891
Kintersville, PA
Ranger XLT
4.0 SOHC
I always loved the dual tanks on my ‘92 F150, only had to fill up about once a week instead of every 3/4 days with the ranger. Got about the maw mpg, just carried way more gas.
racsan
4,317
central ohio
ford/escape
2.5 (4 Cylinder)
2.5/151 I-4
the grey-t escape
yep the “beater with a heater” is a front-wheel drive, heavy one at that. 3000#. The ranger is about the same weight with no cap /tool box/grille guard. Ranger is a manual, hhr is a auto od.
If I had a mustang Id never manage 20+ mpg, Id have my foot in it too much, driving it like I rented it. lol
Kirby N.
March Truck of The Month
