• Welcome Visitor! Please take a few seconds and Register for our forum. Even if you don't want to post, you can still 'Like' the posts that you read.
Drl module location 2009 ranger v6
Rock Auto 5% Discount Code: 4FF3E9EEA14805 Expires: October 1st, 2020
Cjp1956
New member
Orillia, Ontario, Canada
Thank you, I'm new on this site,
I'm not sure what years are the same. I haven't purchased this yet but the owner says that the drl will come on whenever. Even when the truck is off with the keys out
fastpakr
Forum Moderator
659
Roanoke, VA
It doesn't help that the US rangers didn't get the DRL feature (as far as I know) so your sample of people that might know the answer is significantly reduced.
pjtoledo
Well-known member
496
Toledo Ohio
Fords
3.0 2.3
get outta my way, I'm falling!
in the 2005 wiring diagram book it's part of the smart junction box. I don't know if it has a separate relay inside the SJB.
Cjp1956
New member
Anyone with the Canadian ranger have an answer or suggestion as to why this is happening
pjtoledo
Well-known member
496
Toledo Ohio
Fords
3.0 2.3
Cjp1956
New member
Ok but because the drl's are required in Canada I doubt the dealer will disconnect them. Even if they could. This guy just pulls the pos cable off the battery when not in use so it doesn't drain.
Not sure what the smart box is worth or if that's even the problem yet.
sgtsandman
Aircraft Tank Diver
Forum Moderator
2,239
Aliquippa, PA
2011 & 2019
Ford XLT & FX4
4.0 SOHC & 2.3 Ecoboost
31X10.5R15 & 265/65R17
I sniff fuel for a living. Don't judge me!
There is a few Canadians that are regular posters here. They might not check in the introduce yourself section of the forum. You might want to post your problem in either the general section or the electrical section where people are more likely to look.
Welcome to the forum and I hope one of them can help you.
Dirtman
Custom Text Here
6,912
41N 75W
It's up there.
It's down there.
Round.
Not to get off topic here but why do the daytime running lights require a "module"? It's just headlights that you can't turn off so why are they not just simply wired to come on when the truck is running? What about that requires any form of sophistication? :dunno:
sgtsandman
Aircraft Tank Diver
Forum Moderator
2,239
Aliquippa, PA
2011 & 2019
Ford XLT & FX4
They run at a lower wattage for one. I'm sure there is some circuitry to make sure the turn on and off with the truck and are disabled when the head lights are turned on.
Dirtman
Custom Text Here
6,912
41N 75W
It's up there.
It's down there.
Round.
Ahhh, I didn't know they reduced the power.
sgtsandman
Aircraft Tank Diver
Forum Moderator
2,239
Aliquippa, PA
2011 & 2019
Ford XLT & FX4
Most of them do. I think it has to do with not killing head light life by running full blast all the time. But that is purely conjecture on my part with no authoritative sources to point to other than they run at reduced power if there isn’t a separate DRL in the system.
snoranger
Forum Moderator
ASE Certified Tech
3,819
Jackson, NJ
'79,'94,'02,'17
All Fords
